Mapbox API Problem
CosmigonoN
Hello everyone!
Glad to participate in this forum, this being my first topic!
I will tell them:
I'm having trouble trying to load maps into TSRE5 from the Mapbox API.
Until a week ago, I never had a problem with this...
According to the log.txt file, the problem is a change to the Mapbox API token format, which is preventing the map upload from working correctly.
I quote what is stated in the log.txt file:
"Legacy Static Image requests are no longer supported. To continue making Static Image requests, please use the modern Static Images API. See https://docs.mapbox.com/api/maps/static-images/ for more information"
In the link that appears in the log.txt file report, I could not find information on how to solve this problem.
However, in the settings.txt file, I have the following entry:
imageMapsUrl = http ://api.mapbox.com/v4/mapbox.satellite/{lon},{lat},{zoom}/{res}x{res}.png?access_token=MY _API
* Where it says MY_API is the token of my API key.
Is anyone using the Mapbox API having the same problem loading maps in the route editor?
I will wait attentively for your answers.
For now, I will continue to investigate to try to solve this problem.
Greetings to all!
Cosmigonon.
