Texture - "Put" - large swaths ?
Scottb613
Hi Folks,
Is there a way to "put" large swaths of Terrtex Tiles - other than holding down the mouse button and painting each tile ? When I do this for large areas - TSRE seems prone to crashing... Similar to Mosaic where you can select the corners and it auto fills everything in between...
Thanks...
Scott
Select patches using crtl or shift. And then use right click context menu and choose put texture.
Scottb613
Thank you so much - will give that a shot...
Scott
