I've cross-posted this to the Train-Sim forum as well but maybe someone here can help...I have noticed this as I re-build in various areas...The TDB shows everything there but the TDB line is gone. ESPECIALLY since it is up against a switch, I "remove" the switch from the database, remove the track that has the error, and then add them both back and things line back up again.
I can run over it with almost no problems, the trains expand/contrast when going over these errors in ORTS. Does anyone have a fix or an idea?
-Frank C.
