		Posts: 46		Joined: 16 Jan 2019, 15:21
			If I add a PickupType ( _FUEL_COAL_ ) to a route with the TSRE, this item is not displayed in the MSTS AE.
Probable cause: last line in .tit and .tdb
With TSRE
PickupTrItemData ( 100000 00000000 )
With MSTS RE
PickupTrItemData ( 100000 00000300 )
300=Coal, 280=Water, Diesel ?
Regards Jan
		Posts: 364		Joined: 15 Jan 2019, 18:10
			Thanks. I'm going to look at it.
Other pickup types are fine?
			For Diesel = 380.
I never saw a working freight load in the MSTS on german routes.
Regards Jan
			But the problem is that my MSRE writes only zeros here:
			Use the second link in the thread above
If you want to reset the track editor and the MSTS options at the same time, you can use the "Reset MSTS completely.reg" instead.
			Setting the PickUp seems to be implemented idiot-proof. Thanks KUJU
You are setting a PickUp. There is only "0" in the second Number after the fist save.
Now you are going back and Move the PickUp. Now the second number is correct but the PickUp is empty!
Now i had the same Problem as you. Wenn i fill the PickUp again the second number is only "0". Something's going wrong here.
I'll test it again later on another route.
Regards Jan
