Hi I´m triying to create an activity with TSRE5 but when I place a new consist it stop working and crashe also I have a lot of consist in the tracks but it stops working when I put one more i need help please, here i leave some info:
TSRE version: TSRE5 0.6951
When I open the log:
conid "e:/msts/trains/consists/1616_aislada.con"
-6452 -14418
-943.024 1 168.821
coninit init 1319 523.081
ok
-6452 -14418
-904.835 1 102.083
coninit init 1328 193.179
ok
[I] Sd Shape: not exist "E:/MSTS/TRAINS/TRAINSET/RenfeUacs_OR/RenfeUacs_20277fa.sd"
[I] "e:\\msts/trains/consists/1616_aislada.con"
[I] ""
[I] "unselect"
[E] qUncompress: could not allocate enough memory to uncompress data
[I] "SQC"
TSRE5 stop working while creating activity
In your log file I see out of memory error.
It can be caused by two things:
- your computer has not enough memory.
- TSRE crashes during loading broken file.
1. Try new TSRE version .697 .
2. Check your memory usage while using TSRE.
3. Check if there is no broken file or unsupported by TSRE.
Ok i will try the new versiónGoku wrote: ↑28 Jan 2019, 17:03 In your log file I see out of memory error.
RAM: 16GB
GPU: GTX960 4 GB
CPU: I5-4440 3.1GHz
GPU: GTX960 4 GB
CPU: I5-4440 3.1GHz
But does it still crash?
Check the train files then.
