Terrain Painting and switches
Posted: 24 Apr 2020, 14:43
I'm going to be "bad" here and cover TWO subjects in one thread.
Question 1) is there anyway to make the tile lines, which are very obvious, disappear? I am doing the texturing via "texture" with a loaded texture? Some areas it is VERY noticeable and bad looking! I've brought the brush/intensity down to 1 and up to 100 and everywhere in-between with no luck.
Questoin 2) I love TSRE but I do have a question about signal links for you. If I remember right, in MSTS you can link a signal to the track between switches but in TSRE I can not...Is there a way to get this updated in a future update?
Switch 1611 and 1615 are separated by 5m of track (as MSTS needs).
Switch 1615 splits to S1615 and T1503.
Switch 1615 splice to T1505 and T1507.
I want to tell a signal behind Switch 1611 to look at just the 5 METER section between it and S1615. Right now I'm having to tell it to look at T1505 if I want the LINK to work
I hope you are staying well and healthy!
-Frank C.
-Frank C.
