I'm opening this thread to find a solution to this problem that occurs in TSRE5 with the Track Database.
It turns out that the railroad line I'm developing in TSRE5 has some segments where the track orientation is practically 90 degrees to the Tile Grid.
The problem occurs in the track nodes of those pieces that have a 90-degree orientation.
The Tsection lines are misaligned and don't match the lines of the other track pieces. However, the track shapes do match.
I've attached some images below for a better illustration:
This happens when the track pieces are selected and re-entered in the TDB by pressing the "Z" key.
Has this happened to anyone else?
And if so, does anyone know of a solution to this problem?
I look forward to your response.
Best regards.
