I have seven carspawner lists in addition to the MSTS default carspawner in the route I am working on. Recently each of the seven extra "Open Rails" carspawners has been showing up in TSRE5 as the Default, even though on selecting the offending carspawner it is still identified as the correct "OR" carspawner. However, these carspawners continue to show correctly in OR, as far as I can tell. So the bug seems to be confined to TSRE.
Any thoughts?
Carspawners all showing as Default
Well, I've been somewhat underwhelmed by the response! However, I think I have tracked down the cause of my problem, which I post here in case anyone else experiences the same issue or if the bug, and it is a bug, can be addressed.
I recently added two lines to my setting.txt file, viz.:
autoFix = true
loadAllWFiles = true
I did this so that I could correct errors flagged in the "Errors and Messages" window, which I was able to do. It occurred to me that it was after I made this change to settings.txt that I noticed the problem with the carspawners. On a hunch, I changed loadAllWFiles to false. This seems to have solved the carspawner issue.
Martin
autoFix = true
Martin
