Problem with Consist Editor
Posted: 16 Jan 2019, 19:15
by PNRailway
Goku,
I am having trouble accessing the consist editor on your great program. When I run the bat file to start the editor a window fashes on the screen and then the program bombs out. I have tried this with several different releases of the program and it happens on all of them. I am running Windows 7 professional with 16 gb. of ram. Any help you could provide would be greatly appreciated.
Paul
Re: Problem with Consist Editor
Posted: 16 Jan 2019, 19:28
Do you have 64 bit or 32 bit windows?
You have to first open EXE file. Does it work?
If yes, then open .bat file in notepad and check if the EXE filename is correct.
Posted: 08 Aug 2019, 10:09
by xavivilla
I have a friend who has problems starting the Consist Editor.
The first window opens and when you click on Load, the program crashes.
The same goes for the Route Editor.
I attach the log.tex file
Thanks for your help.
Posted: 08 Aug 2019, 18:02
I think that TSRE crashes because of faulty ACT file.
"c:/users/emilio/msts/routes/vallarizasoria/activities/tren postal 19953.act"
converting to UTF16
#ACT - undefined token: "v"
#ACT - undefined token: "t"
Try to remove it.
Posted: 08 Aug 2019, 21:01
by xavivilla
Thanks for your quick response. I will communicate if the problem has been solved.
Posted: 09 Aug 2019, 11:01
by xavivilla
My friend tells me that the problem was resolved by removing the .act file
Thanks again for your help.
Posted: 13 Jun 2020, 11:06
by debarun1998
I installed TRES 5 v0.698.1 . The consist editor is opening and I am even able to build a new consist . But after building when I try to save it , it doesn't save. Please help!!!
Posted: 13 Jun 2020, 16:28
by Septf
after making your consits, click on file then save. other question, where is TSRE installed?
Posted: 13 Jun 2020, 17:19
by cr-stagg
debarun1998 wrote: ↑13 Jun 2020, 11:06
What is the FULL path to your TS install? As in D:\1MSTS or C:\Program Files (x86)\Microsoft Games\Train Simulator?
If it is C:\Program Files (x86)\Microsoft Games\Train Simulator, then Windows Security is not allowing the files to be saved in that location and is saving them elsewhere. Solution: Move your TS install outside of the Program Files folder.
