Activity Editor Work ?
Scottb613
Hi Folks,
I realize the activity editor is still a work in progress - I know I have to create paths and consists externally - but does it work ? I’m pretty familiar wirh MSTS AE and used it for years to create many activities... I’ve tried several times to use TSRE to build the most basic activity - everything looks right - I create a player service - assign existing consist - assign existing path - save on exit - and it shows “error” in ORTS activity list... I’ve tried this a coup,e of times from scratch - but no luck - error - every time... When I open the “act” file in a text editor - it’s only about 20 lines and everything else is missing...
Any ideas ?
I won’t be home until next weekend vor acces to my PC again...
Thank you...
Scott
Yes, it works. Although you have to maintain steps order.
Did you see this AE guide?
https://docs.google.com/document/d/1hvt ... sp=sharing
I think that you probably forgot to select your service as a player service.
Scottb613
Thanks so much - I’ll take a look and read it thoroughly before I attempt this again next weekend... Have a good day...
Scott
