Can We copy Multiple objects ??!
ADITYA3191
Hi sir , If I have placed bushes and Grass On trackside, now i want same pattern of bushes and Grass on other side of track , then is there any way to copy multiple objects ????
Select one object, then hold the control key and select the rest.
Ctrl C to copy
Ctrl V to paste
H to set every object to ground level.
You can translate and rotate multiple objects as well.
Just beware of rotating near to or across a tile boundary, some of your selection may "disappear" over to a remote corner of the next tile. If so, delete and copy again somewhere else.
ADITYA3191
Thank You So Much For Your Help
