I found out that on 2 good russian routes i cant see the land surface in TSRE on all the tiles. Of course "Hide terrain shape" is OFF. Maybe the bug is with Quad Tree. How to fix it?
https://imgur.com/a/AZte8gm
Land surface cant be seen
Yes. The problem must be with QuadTree. If the route is made using MSRE, check if route_dir/td/td_idx.dat is present and all .td files are listed there.
Or, just disable QuadTree support using:
useQuadTree = false
In settings.txt. It will work only if route is made using standard 2x2 km tiles.
useQuadTree = false
