CE flipping items
When one flips an item in a consist there is no indication in the Consist Units list that the item is flipped until another item is added to the consist. What I am sayin is that the [F] indicator before the item file name does NOT appear until an item is added to the consist. Yes the item in the Consist display will be flipped, BUT if the left and right sides are mirror images then one cannot tell that the items are flipped. Tried flipping another item, tried deleting an item, and tried shifting an item but none of these actions caused the [F] to appear. Only adding an item would update the Consist Units list to display the [F] to indicate flipped items.
Thanks. I will fix it when I'll have a chance to work on TSRE.
Fixed in next exe update.
Loading progress and fixed filter total number too.
