I have used files from "Open Rails Litter" and "Open Rails Tree litter" in a tile for the "The Clinton Subdivision" route from the Trainsim library. The files use dds textures. The problem I am having is the TSRE crashes immediately when when I go to reload the tile. The crash will occur about 9 out of 10 times but now and then I will get lucky and it will open. I am using TSRE5 v0.6974 .
Do you have any thoughts?
Mark
Problem with dds textures in tile
Are you sure that it crashes due to texture file? Does it work when texture file is removed?
