I'm going to be "bad" here and cover TWO subjects in one thread.
Question 1) is there anyway to make the tile lines, which are very obvious, disappear? I am doing the texturing via "texture" with a loaded texture? Some areas it is VERY noticeable and bad looking! I've brought the brush/intensity down to 1 and up to 100 and everywhere in-between with no luck.
Questoin 2) I love TSRE but I do have a question about signal links for you. If I remember right, in MSTS you can link a signal to the track between switches but in TSRE I can not...Is there a way to get this updated in a future update?
Switch 1611 and 1615 are separated by 5m of track (as MSTS needs).
Switch 1615 splits to S1615 and T1503.
Switch 1615 splice to T1505 and T1507.
I want to tell a signal behind Switch 1611 to look at just the 5 METER section between it and S1615. Right now I'm having to tell it to look at T1505 if I want the LINK to work
I hope you are staying well and healthy!
-Frank C.
Terrain Painting and switches
Signal linking works for me, even for the small track parts. As others for help.
There is a problem with tgatool or aceit. One of these programs copies the right pixel row to the left side when compressing - or vice versa. I had the same problem with these lines a few years ago - and in some routes you can also find these broken tertex.
For me it has nothing to do with the TSRE5.
I had to recreate all textures and make sure that they were compressed only once.
Regards, Jan
Regards, Jan
Goku,
In response to the signals, let me explain a little more in detail. On a yard ladder, in MSTS I was able to link to the BLUE X or the GREEN X's. In TSRE, I am only able to link to the GREEN X's for some reason...I am just not clicking on the track (under the BLUE X) right or...?
-Frank C.
-Frank C.
See my response over on TS.com's forums...I don't think it's related to what you described as I'm using the COLOR/TEXTURE Paint tool of TSRE.Kapitaen13 wrote: ↑25 Apr 2020, 06:59 There is a problem with tgatool or aceit. One of these programs copies the right pixel row to the left side when compressing - or vice versa. I had the same problem with these lines a few years ago - and in some routes you can also find these broken tertex.
Regards, Jan
-Frank C.
You are probably clicking too close to the next junction. Click closer to the junction you want.
Then ask someone who know how to link for help.
