Missing Tile On Geo Import
OldVern
Apologies if I've asked this previously, but can you remind me of the process to fill in the terrain data on the "start" tile, which is left without terraforming after creating the remaining route tiles, which have had the DEM data correctly applied. I've tried clicking Load Height and nothing happens.
Edit: Forget the above, I worked it out (you need to actually select the tile).
