Hi Goku
I have in the speedpost.dat many Speedpost_Set, where under
Speed_Sign_Shape ( )
No shapename is entered, they have only a Speed_Warning_Sign_Shape
Speedpost_Set
Name ( CHGeschwRed<Hoheziffern )
Speed_Warning_Sign_Shape ( CHSpeedlimitAnzeige.s 1
-0.18 4.4 -0.01 0)
Speed_Resume_Sign_Shape ( )
Speed_Digit_Tex (CHSignalZiffernhoch.ace )
Speed_Text_Size ( 0.55 0.25 0)
TSRE5 doesn’t show under Objects > SpeedWarning such speedpost.dat entry’s,
if there is no shape_name entered under “Speed_Sign_Shape”.
Can you please modify TSRE5 so that it can show also such Speedpost entry’s.
I have also “misused” such entry’s for different kind of plates where the Routebuilder should have the possibility to enter Number’s. ( Gradientplates, Signalnumbers ect. )
Speedpostsets containing only a Speedwarnigshape are not displayed
It should work. Maybe the problem is with missing space between number and ) ?
edit:
The problem is with empty:
TSRE requires non empty definition or nothing.
Why do you use empty definitions. Is it required for MSTS/OR?
edit:
Hallo Eugen,
Ich meine beim MSTS mussten auch die Einträge von Speed_Resume_Sign_Shape und Milepost_Shape vorhanden sein.
Ich arbeite mit den Hektometer Tafeln als Speed_Warning_Sign_Shape.
Die speepost.dat ist vom MSTS 1:1 übernommen - ohne Probleme.
Gruss Jan
@ Goku: It would be nice if the numbers were displayed.
Gruss Jan
Hi Golu,
Yes, so it is.
MSTS has required this empty definitions.
the Schweizer Signalsystem exist since many Years. All Time compatible for MSTS and OR.
So it would be nice If you could modify TSRE5, so that this entry's would by displayed also in the TSRE5.
I don't see a solution to modify the Signalsystem so that it is compatible again for MSTS and OR.
With the Solution of Kapitän13 the the Speed_warning_signs where displayed under "Mileposts"?
Yes, so it is.
So, the empty definition
Should be treated as no definition?
Hi Goku,eugenR wrote: ↑06 Nov 2019, 19:37Hi Goku,Goku wrote: ↑03 Nov 2019, 15:55 Check this fix:
http://koniec.org/tsre5/data/TSRE5_v0.69753.exe
Not tested by me.
all Speedplate are now displayed and can be selected for placing.
Thank you for the modification.
Thank You for fixing the Problem.
As all is O.K. can you please publish the Link to the new Release also under "NEWS"?
regards,
