Alternative to Google maps API
Use this forum to find or post TSRE tips & guides.
Karthik27
Hello can any one can help me in creating Mapbox API key
I am From India And I am covering Southern Part of India.
Somebody please guide with entire Step.
Thank you.
a408814361
Landlord,Now the key cannot be used.Is there any other way to import a map? thankyou。
Septf
The problem of importing images from the Mapbox API has been solved by Kapitaen13 from the TSSF.eu forum
code to add in the settings.txt file
 imageMapsUrl = https://api.mapbox.com/styles/v1/mapbox/satellite-v9/static/{lon},{lat},16/{res}x{res}?access_token=Your key API Mapbox
thanks to him for finding this trick and sharing it
Kapitaen13
Error message
Legacy Static Image requests are no longer supported. To continue making Static Image requests, please use the modern Static Images API. See https://docs.mapbox.com/api/maps/static-images/ for more information.
New API
https://api.mapbox.com/styles/v1/{username}/{style_id}/static/{overlay}/{lon},{lat},{zoom},{bearing},{pitch}|{bbox}|{auto}/{width}x{height}{@2x}
For TSRE
imageMapsUrl = https://api.mapbox.com/styles/v1/mapbox/satellite-v9/static/{lon},{lat},{zoom}/{res}x{res}?access_token=+YOUR_MAPBOX_ACCESS_TOKEN
The zoom has changed and must be entered manually.
Standard Terrain
Raster Image Z18 =17
Raster Image Z17 =16
Distance Terrain
Raster Image Z18 =13
Raster Image Z17 =12
Example: Standard Terrain Raster Image Z18 =17
imageMapsUrl = https://api.mapbox.com/styles/v1/mapbox/satellite-v9/static/{lon},{lat},17/{res}x{res}?access_token=
CosmigonoN
Kapitaen13 wrote: 22 Apr 2023, 13:54 Error message
New API
For TSRE
Standard Terrain
Distance Terrain
Thank you very much for the information!!!
I have tried it, and it works!!
Greetings!
xavivilla
Thanks for the explanation, it works fine.
I apologize for my English of translator
Manuel18
New API
For TSRE
Standard Terrain
Distance Terrain
Sorry to bump a old thread. This is correct, and thanks for the feedback. (first post fixed)
I wanted to update my raster satellite files and find out there is a Zoom level error. This is not Goku fault but there should be a "comfortable" solution.
