Platforms and sidings.
I noticed that if i change the lenght of the siding/platform interactive (for example make it 3 times shorter moving one of its endpoints towards another) and save in TSRE the previous lenght of siding continue to appear in MSTS Mapper program (the only purpose of that program is to read tdb and present it visually) - so it does not update in MSTS Mapper after changing in TSRE but will update if i change it in MSRE. Why? Is it a bug?
Interesting. I will check it.
Goku wrote:
22 Feb 2019, 19:59
If you need the explanations here it is:
https://imgur.com/a/0PP7lpE
the green lines show the borders of the siding where it should be and the red line on MSTS Mapper show where it is by fact.
Oh, but it is custom software?
Do you know if the error occurs also in MSTS AE?
If not, then it would be nice to know how to use this custom software. Is there English version or only Russian?
It may be a bug in updating TrItemPData or TrItemRData values in Track Item definition. OR and TSRE doesn't use them, but TSRE tries to write all for MSTS compatibility.
Goku wrote:
23 Feb 2019, 21:01
Already tested. There is no such a bug in MSTS Activity Editor. The siding lenght is properly updated after modification in TSRE.
MSTS Mapper is a russian program, developed by Галета Антон (Net), the latest version is created in 2015.
You can download the latest version here:
http://disk.zaborin.ru/000196
Bug info updated: you cant see the proper length of siding/platform in MSTS Mapper ONLY if you move the orange/green pyramid of the siding/platform by mouse (most users do so) BUT if you use the numpad or you use mouse at first and after that just move the pyramid left-right with the numpad and save after that than it is poperly displayed in MSTS Mapper. You should move BOTH pyramids with numpad, one after another, and than save, if you want your siding/platform to be properly seen in MSTS Mapper. So the bug can be with writing in some database files after moving the siding/platform using mouse.
Thanks for this useful investigation.
Indeed in mouse function there is one function missing:
updateTrItemRData();
This functions updates TrItemRData values.
Thanks. It will be fixed in next version.
Goku wrote:
25 Feb 2019, 17:19
Looking forward to that. And the question - what if i forget about some sidings that i moved only with mouse so no TrItemRData updating of that sidings ? will it cause any critical bugs in MSTS or only will be problems with representing it in Mapper?
Archimage wrote:
25 Feb 2019, 17:23
No critical bugs. I think that even MSTS Game uses platform track positions and not R data. I think that R data is used for visualization in MSRE.
But I'm not sure. In the worst case the platform will just have different length.
Fixed in new version.
