I need help with TDB
Posted: 16 Apr 2022, 17:26
by a408814361
i make road now,i find Station coordinates is wrong,it can't play ,i delete the road TDB,but Train Simulator Editors & Tools cannot rebulid TDB,What should I do next, please? how to make TDB don't use Train Simulator Editors & Tools?thank you。
Re: I need help with TDB
Posted: 17 Apr 2022, 12:22
by Switch Tender
If you deleted the TDB you'll have to start over unless you have a backup somewhere.
Maybe you can rescue it from the recycle bin.
Posted: 19 Apr 2022, 19:38
by eolesen
Can you clarify which DB you deleted?
If it's the TDB, you'll need to manually re-select every track piece in the route for it to be operable.
If it's the RDB, you should be able to restore that by clicking on road sections. Again, you'll have to click on every road piece you expect to function with car spawners.
