TSRE version 0.7
TSRE Announcements. Read only.
New version.
64 bit: http://koniec.org/tsre5/data/TSRE5_v0.7.001.exe
32 bit: http://koniec.org/tsre5/data/TSRE5_v0.7.001x32.exe
How to install:
1. Download EXE file.
2. Run EXE file. TSRE will automatically download required data.
3. Use it.
Errors?
If TSRE shows error about openAL libs:
- go here and download openAL lib for your system: http://koniec.org/tsre5/data/openal/
- place it in TSRE directory.
Other installation errors?
Try installing TSRE in new, empty directory. Make sure that TSRE has access to the internet.
What's new:
0.7.001
- some dynamic track bug fixes
- fixed bug when placing elevated complex tracks and shapes
- fixed bug when signals face wrong direction after track vector editing
- TSRE creates an empty graphic.ace file when making a new route, so MSTS won't crash on load
- multiplayer editing demo
0.699
- autoFix function. TSRE will remove all broken objects if autoFix is set to true in settings.txt
- new error detected by TSRE - signal linked to wrong trackNode
0.698
- introduction to error & messages. New window + route checks + new option: "loadAllWFiles = true"
- randomized object placement
- multiple ref files
- shape viewer reload file
- geo terrain editable offset
- improved kml rendering - try "markerLines = true"
- improved Image Maps download
- seasonal editing
- option to customize number of recent items list: "numRecentItems = X"
- many fixes and features already forgotten XD
0.69752
- fixed RE shape preview window
0.69751
- fixed selection bug
0.6975
- shape viewer
- fixed shader shadow bug
- fixed bug when moved carspawner marker is not properly displayed in some tools
0.6974
- fixed bug when editing water on tile with water disabled
0.6973
- fixed Quad Tree bug (disappearing terrain)
- fixed bug when moved platform marker is not properly displayed in some tools
0.6972
- fixed bug with loading DDS textures defined directly in data files.
- fixed bug when train path stations were not in order while making services.
0.697
- new installation method. TSRE uses now Tar archiwes and own tar file extractor instead of windows .cab files. So, now automatic installation should work on all operating systems.
0.6963
- elevation info for dynamic tracks and rulers
- set position Y value for group of objects
- edit position of signal shape in properties window
- more actions available from the context menu
- pick elevation for placement -> easy placement of elevated track using short segments
- new option "useTdbEmptyItems = false" may help editing broken routes?
TSRE update:
http://koniec.org/tsre5/data/TSRE5_v0.6972.exe
0.6972
TSRE Update:
http://koniec.org/tsre5/data/TSRE5_v0.6973.exe
0.6973
TSRE Update:
http://koniec.org/tsre5/data/TSRE5_v0.6974.exe
0.6974
TSRE Update:
64 bit: http://koniec.org/tsre5/data/TSRE5_v0.6975.exe
32 bit: http://koniec.org/tsre5/data/TSRE5_v0.6975x32.exe
0.6975
- shape viewer
TSRE Update:
64 bit: http://koniec.org/tsre5/data/TSRE5_v0.69752.exe
32 bit: http://koniec.org/tsre5/data/TSRE5_v0.69752x32.exe
0.69752
TSRE Update:
64 bit: http://koniec.org/tsre5/data/TSRE5_v0.69753.exe
0.69753
- fixed crash when animations defined in shape file, but no animations inside
- fixed speedpost data loading bug
TSRE Update:
64 bit: http://koniec.org/tsre5/data/TSRE5_v0.698.exe
32 bit: http://koniec.org/tsre5/data/TSRE5_v0.698x32.exe
0.698
- seasonal editing
TSRE Update:
64 bit: http://koniec.org/tsre5/data/TSRE5_v0.699.exe
32 bit: http://koniec.org/tsre5/data/TSRE5_v0.699x32.exe
0.699
